How to cap off an unused light switch with 3 black wires
Old 08-10-15, 02:11 PM
We have a weird light-switch in our house that has never seemed to work as long as we've owned it. The switch is in a strange location - about thigh-high up the wall near the fireplace. We want to place some bookcases near the fp so I'd like to cap it off and replace it with a blank faceplate.
Opening it up - the switch has 3 white wires capped together, one capped ground wire, and three black wires hooked up to the switch. How do I cap the three black wires so that any subsequent outlets in the chain will continue working? Can I twist all three together? Individually? Two-and-one?
Thanks for any help
Old 08-10-15, 02:18 PM
Tolyn Ironhand's Avatar
Welcome to the forums!
That is likely a fan switch for the fireplace. I would just leave the switch and place the book cases in front of it. No harm, no fowl.
Old 08-10-15, 02:22 PM
ray2047's Avatar
So it is most likely for a fire place blower.
Cap the black (and white) to the blower then connect the other two blacks together. Use a multimeter or neon test light, but not a non contact tester, to determine which cable is power in. Disconnect the other two blacks and see what it kills. Then reconnect the blacks one at a time to see which wire is associated with what went dead.
Old 08-10-15, 02:30 PM
No harm, no fowl.
No harm, no birds.
(Hint: Look up the definition of foul.)
Old 08-10-15, 02:33 PM
Jen has not posted her location so it is possible that this IS a three-way switch and the three black wires are because the house has conduit. I personally would not assume it is a fan in conjunction with the fireplace without more information.
Jen, some pictures of the switch and the wiring may help.
Old 08-10-15, 02:38 PM
I have a fireplace blower? Wow, 17 years here and never knew that (as I said, the switch has never seemed to do anything. Now I need to investigate that before deciding whether to get rid of the switch.
Oh - I am in the greater Seattle area and the house was built back in 1992. It looks to have been a rush job, every-time we've gone to replace something we've found shortcuts (like particle board underlayment in the bathrooms). The wiring is maddeningly non-logical as well - I've had outlets where one in the middle of the wall seems to be on a different circuit from the two on either side.
Old 08-10-15, 03:09 PM
It is likely that there is a thermal switch on the fireplace as well in series with the wall switch. This makes it that the fan will not come on until the fireplace gets warm/hot. My house was built in the late 70's and it has a thermal switch.
