Plastic weather proof FSB box
Old 08-15-15, 08:38 PM
Received 1 Vote on 1 Post
I was doing some wiring outside and used a plastic FSB box.
I had to run conductors from two places to this box then from there to a third location...this over several days and it rained every day, so I had to open and close the box cover multiple times.
By the time I am all done, I noticed the four metal screws that go onto the weatherproof cover have already chew through the four holes on the box one too many times so the screws spin and no longer very tight.
I can't change the box now that all the conductors are in and the boxes and conduits are glued.
I could try using larger diameter screws, but they may break the plastic screw holes on the box.
Suggestions?
Old 08-15-15, 08:50 PM
P
Temporarily Suspended
If you don't want to try larger diameter screws, remove the screws, put some liquid nails on the threads & reinstall them. They will still spin but when the glue dries, they will be secured.
Old 08-15-15, 11:00 PM
Received 1,037 Votes on 961 Posts
If you are using standard 6-32 screws then you will need to convert to small #6 or #8 self tapping screws.
Old 08-16-15, 04:51 AM
Geochurchi's Avatar
Received 67 Votes on 63 Posts
You could also try longer screws,they may grip further down in the box.
Geo
Old 08-16-15, 04:45 PM
F
Received 35 Votes on 27 Posts
There is enough "meat" in the stripped out holes to drill and re-tap for 8-32 screws. That is what I would do.
