Connecting exhaust fan above shower
Hello,
I'm installing an exhaust fan above a shower in a new bathroom I'm building. There's a note in the manual that if installed above a shower it must tie into a GFCI protected branch circuit. I'm planning on having a dedicated circuit for the GFCI outlet next to the sink. Can I tie the exhaust fan (and only the exhaust fan) into this circuit via the GFCI's LOAD screws? I can't remember whether not not the GFCI outlet net to the sink has to be by itself. If it matters the type of fan and watt rating is below.
UPDATE: I'm also installing lights above the shower and apparently they have the same GFCI requirement. So perhaps I'll just do the GFCI at the breaker for the two lights and the fan. Is this doable?
Thanks!
Thanks!
pcboss: I have never seen lights that required gfi protection over a shower or tub.
CasualJoe: The easier and more common way would be to not put the fan over the footprint of the shower.
Other thoughts, I'm going to need two circuits in the bathroom regardless so I'll just plan on making the fan and lights on the same GFCI breaker\circuit.
Thanks for the help!
It is aerodynamically advantageous to put the exhaust fan above a shower (or near the toilet at about tank level).
It does not hurt to put the exhaust fan on a ground fault circuit interrupter protected line.
