Non-reversible 220 motor, L1 and L2
Old 08-24-15, 03:38 PM
So, I've got a pool pump motor that is 220V, non-reversible, CCWPE (counter clockwise, pump end). From the panel, there are 3 wires consisting of 2 conductor wires and 1 ground. Is it correct to say that it doesn't matter which conductor wire connects to L1 and L2? I think that's what I've pieced together from tid-bits of what I've read online. If this is correct, no matter what wire connects to L1 or L2, the motor will still run CCW?
Old 08-24-15, 03:45 PM
ray2047's Avatar
That is correct. .
Old 08-24-15, 03:56 PM
Thanks so much! Is that because one end of the start winding is permanently connected? Therefore, the motor will only run in one direction? In this case, CCW.
Old 08-24-15, 04:10 PM
If it's a fixed direction motor then the start winding is permanently connected at one end to line.
Old 08-24-15, 04:36 PM
Got it! Thanks so much for the response!!
