Have to run 40 amp cable for wall oven
Old 08-25-15, 01:07 PM
B
I will be using 8 gauge.My question is can I use 8-2 copper NM/WG.It has a small ground in it. Or should I use 8-3 copper romex- not sure if it would have a ground wire in it. The run will be about 100 ft. Live in NYC.
Old 08-25-15, 01:16 PM
I
Received 43 Votes on 41 Posts
Almost all cooking equipment require 3 conductor plus ground; which in this case would be 8-3/g. The manufacturer's instructions should specify if it is 240V only or 120/240V. If you don't know which oven it will be, go with the 3 conductor for maximum compatibility.
It is my understanding that NM is not permitted in NYC, someone else needs to confirm.
Old 08-25-15, 03:29 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
Modern cables will have a ground means.
NY is more strict than other areas. Check with your local code officials.
