Dead basement receptacles
So I had Outlets put in my basement like a year ago. They all worked until a couple months ago when they all suddenly stopped working(5 of them). I've replaced the circuit breakers, and the outlets and yet it still doesn't work. What could be the problem?
Sorry to tell you this but you replaced the two things least likely to be the cause. Is this a finished or unfinished basement?
Are you saying the non working receptacles are on more than one breaker? Have you read: http://www.doityourself.com/forum/el...ther-info.html?
Do you have a multimeter, preferably analog? (A non contact tester won't work for testing but a neon test light or solenoid tester will if you don't have a multimeter.)
