Dedicated 120 V. 20 Amp outlet directly under window?
Howdy fellow DIY'ers,
As you've read in another post, I am converting a 20' x20' garage into a recording studio/Man-Cave. I live in Oregon. I cant find anything in the NEC code for my area that states whether or not I'm allowed to install a dedicated 120 volt /20 amp outlet directly under the window (at 15" from finished floor) for a 20,000 BTU AC Unit.
Now : If I'm not allowed to, I can easily take the window out and simply frame it in with 2x4's and drywall/plywood over it, and just cut out for the AC unit if need be.. Just curious if the inspector will pass me if I install the outlet under the window. Maybe if I tell him what my plans are in the future?
Thanks in adavance,
Danguitarman
Thanks in adavance,
Danguitarman
There is no rule about putting an outlet under a window.
I do it all the time so the lady's can put candles in the window at Christmas time and for A/C units.
*http://www.rapidtables.com/convert/p...TU_to_Watt.htm
It is common practice to put a dedicate circuit with single receptacle under a window. If the garage floor is unfinished dirt or concrete all 120V 15A and 20A receptacles must be GFCI protected. GFCI is not required with 240V receptacles assuming you get the larger AC unit.
