Gray Jacketed 12/2 wire labeled UF-B
Hi again folks,
I sent my wifey to Home Depot to get me a 250 foot roll of 12/2 wire for my garage project. When she got back I noticed that it was exterior gray jacketed cable labeled 12/2 UF-B. My question is this: Can I go ahead and pull that wire through my holes in the studs and connect it to my outlets without failing inspection?
I figure exterior grade UF-B means UF= 'Underground Feeder' for 'B' Burial. If I cannot use it, I'll take it back and get the yellow jacketed 12/2 but it's a 45 minute drive one way to the Depot. I know it sounds like a pretty stupid question however, I was taught that the only stupid question, is the one that is never asked.
Thanks for all answers in advance,
Danguitarman
Danguitarman
U can be used in the same locations as NM. It is just more expensive than NM and harder to work with.
The -B designates 90 degree C insulation.
Thanks pcboss,
Luckily I haven't opened it so I can return it. I don't want to have to fight with it to tuck it into outlet and switch boxes and such. Thank you for the info..
Danguitarman
Danguitarman
Took it back...........
Hiya Folks!,
I returned the wire and got 2-250 foot rolls of yellow 12/2 NM wire for the same price as we paid for the 250 feet of the other stuff.
Any left over will make excellent speaker cables
Thanks , Danguitarman
P.S. All 2 by's drilled, ready for wire. Now to tackle that 20 inch deep trench for my feeds.
