Help with wiring
Old 09-06-15, 09:50 AM
A
Help with wiring
Hello,
I'm hoping someone has a diagram handy that will show the following:
Power into first light from source, then to second light, then to switch that controls both lights. The tricky part is I want power to continue after the switch independent of the switch into-off setting.
I think this can be done using three wire cable between the lights, but I'm having trouble wrapping my head around how to do it.
Thanks for any help!
Old 09-06-15, 10:09 AM
Received 3,416 Upvotes on 3,063 Posts
Welcome to the forums.
The following should be what you are looking for.....
Old 09-06-15, 11:17 AM
A
Resolved
That's exactly it! Thank you.
