generator voltage too high?
I have a 5500 watt briggs generator.
Under no load, the generator is outputting about 130 VAC.
I let it run for awhile and plug in heatgun and it drops to 125-126.
Is that excessive?
PS - The manual says not to tamper with the govener speed.
Is that excessive?
Get a killowatt meter to check the Hz. Some meters can read Hz. I dont know how your checking the voltage.
That is normal to start with a higher voltage..
I adjust my governor as needed after warm up, buts its usually right on from my previous setting. ( just a tang with a spring attached that you move ever so slightly to increase or decrease RPM of motor)
What I do is not worry about the voltage as the Hz are more important.
Hz range from 58-62. I set my gen so I am up around the 62 Hz range, then with load it comes down to the 60Hz area.
