Switch off, 25v ac voltage read
Old 09-06-15, 01:04 PM
Good evening
I saw this once before on a house I had considered buying but didn't and never investigated further. Now I'm remodeling the baby room and run into it again.
I have a 35 yr old house. Outlet that is switched reads 25vac when off from red runner to neutral.
Most outlets are junk and I'm replacing them... Whomever did the original wiring recessed them 1/4 to 1/2 inch too deep and they are breaking upon plug insertion. Will be replacing the switch too at some point soon.
Don't yet know where the 12/3 is run from the switch (suspecting into attic and draped over )
Anything like this leakage potential normal or am I going to be hunting down ghost voltages on every circuit...
Suggestions most welcome
Jason
Old 09-06-15, 01:22 PM
Welcome to the forums.
If you are a serious DIY'er..... get yourself an actual AC tester or an inexpensive analog meter.
A digital meter will usually show ghost or induced voltages due to their very high input sensitivities.
Doesn't matter. The red wire is showing induced voltage from the black due to its close proximity. A perfectly normal occurrence.
Old 09-06-15, 06:26 PM
That's fair. Didn't think to grab the analog meter... I mean digital is perfect, right? (That's sarcasm.. I hear that phrase in my job and try not to strangle people)
So I could verify this is a ghost by loading a small load, say a100 ohm resister, and measure the drop? Or inline current meter or even a clamp. All of those should confirm it's not real....
Turns out that disconnecting one side also shut down the bathroom on the first floor.
I would love to know who wired this place. I fear it was the home owner.
Old 09-06-15, 06:40 PM
ray2047's Avatar
Plug a lamp into the receptacle, turn the receptacle off, and turn the lamp on. You should see ~0 volts.
