Reload this Page >
Single Pole Switch with 3 Wires - Not sure which one is ground?
Old 09-12-15, 09:54 PM
I am trying to replace a single pole switch with 3 wires (2 black and 1 grey), however I am not sure which one is the ground and which one is the live feed. See the attached pictures. I am trying to replace this switch with a dimmer switch. How do I wire in the dimmer switch?
Old 09-12-15, 10:23 PM
Welcome to the forums.
Connect the two black wires on the old switch to the black wire of the new switch.
Connect the gray wire on the old switch to the red wire on the new switch.
Cap off the red/white wire so it can't short out. It won't be used.
You could connect the green to a bare wire if there is one in the box. If not.....cap it off so that it can't short to anything. The switch will be grounded thru the mounting screws to the metal box.
Old 09-13-15, 05:55 AM
pcboss's Avatar
Grounds need to be green, green with a yellow stripe or bare.
