Put lights on their own circuit?
Old 09-13-15, 09:21 AM
I have managed to confuse myself. I know that outlets should be on 12 gauge and lights are 14. I have 5 rooms on one circuit and plan to break them up into individual rooms. If I run 12 gauge wire to a junction box and 12 from there to each receptacle, can I run 14 from the same box to the lights and switches (1 room will be a 3way)? Should I run a sixth line from the breaker of 14 to power the lights in all of the rooms?
Old 09-13-15, 09:28 AM
Received 835 Votes on 782 Posts
If you put lighting and receptacles on the same circuit then you must use all #12 wiring.
I'd put the lighting on its own 15A circuit.
Old 09-13-15, 09:54 AM
Can I put 3 bedrooms and 2 bathrooms on a single light circuit? There will be 2 exhaust fans as well.
Rethinking that: Each bathroom should go on its own 20 amp circuit. This covers me for outlets, exhaust fan, and lights. A single lights circuit for all 3 bedrooms on a 15 amp circuit. Then each bedroom gets its own 20 amp circuit for the outlets. That's 6 circuits for 5 rooms. Is this good practice?
Old 09-13-15, 10:26 AM
pcboss's Avatar
Received 69 Votes on 59 Posts
It all depends on the load. What lighting loads are planned? I doubt you are even close even with one lighting circuit.
Old 09-13-15, 10:40 AM
Planning a ceiling fan in each room. We will be using CFLs for light.
Old 09-13-15, 10:43 AM
That all can be on one circuit.
Ceiling fan with CFL light +/- 60 watts
exhaust fans +/- 100 watts
Old 09-13-15, 12:26 PM
Tolyn Ironhand's Avatar
Received 151 Votes on 135 Posts
Not true. Receptacle circuits are commonly run on #14 and 15 amp circuits.
Old 09-13-15, 01:09 PM
pcboss's Avatar
I think a 20 amp receptacle circuit for each bedroom is way more than you need. Most bedrooms have some lamps, alarm clocks and maybe a tv.
Old 09-13-15, 05:24 PM
How many/amp size circuits would you recommend?
Old 09-14-15, 06:57 AM
I
Received 42 Votes on 40 Posts
Code recommends general-purpose circuits supply 3W / sq ft minimum. Therefore one 2400W (20A) circuit could supply receptacles for up to 800 sq. ft. of general living space. The two reasons you would want dedicated circuits to each bedroom would be if you use window air conditioners or space heaters.
