Reload this Page >
Convert an alarm clock (that is only battery powered) to use AC power? Possible?
Old 09-13-15, 04:27 PM
D
Is it possible to convert an alarm clock (that is only battery powered) to use AC power so that I can plug it in? If so, can you provide instructions?
Old 09-13-15, 05:22 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Given the cost of an alarm clock it would probably be cheaper to buy one meant for 120 volts.
Are you using that many batteries?
Old 09-13-15, 05:43 PM
D
Actually, I just read that is has a "transformer jack". Do you believe they mean a jack to plug in an AC power adapter?
I've attached an illustration they provided ...
Old 09-13-15, 05:49 PM
Received 1 Upvote on 1 Post
By reading those instructions it looks like that the clock doesn't even have a Jack to plug in a power supply. You would either have to install a Jack or where the transformer directly into the unit itself. As stated earlier in this thread you would be further ahead buying a new alarm clock as far as cost and aggravation goes
Old 09-13-15, 06:04 PM
pcboss's Avatar
Sounds like you can use a wall wart power supply.
Old 09-13-15, 06:15 PM
D
A wall wart power supply? Can you elaborate?
And I want this clock because it has sentimental value (plus, a Super Mario Galaxy design).
Old 09-13-15, 06:49 PM
ray2047's Avatar
What size battery, how many batteries?
Old 09-13-15, 06:53 PM
D
Ray, the illustration image in one of my previous posts shows the clock (4 aaa batteries).
Old 09-13-15, 07:59 PM
ray2047's Avatar
That would be 6 volts if in series. 6 volt (500ma or larger) DC wall warts are common. You probably have a couple in your junk drawer if your like me. In a case like this I substitute wood dowels for the batteries and a screw on the end with a wire from the wall wart to supply the voltage. If you post a picture of the battery compartment (batteries removed) I can be more specific. Note my way does not require opening the clock or making any changes or permanent connections.
