is 15A switch on 20A circuit safe?
Old 09-13-15, 08:18 PM
Tried to buy 20A switches today for my new bathroom fan and lights, but there weren't any. Does NEC really allow me to use a 15A switch? Is that safe? Suppose somebody put a nail through the wire. Wouldn't the switch fail before the breaker tripped?
Old 09-13-15, 08:22 PM
pcboss's Avatar
A 15 amp switch is fine. Rarely are you switching a 20 amp load, if ever in a house.
A nail thru the wire may create a short and trip the breaker.
Old 09-13-15, 08:27 PM
ray2047's Avatar
Yes.
Probably not but even if it did no harm. Switch rating is based on the expected load. If you hooked it a load that actually exceeded 15 amps then the contacts might have a shorter life but no real consequences except a failed switch. In reality lighting load will be far less then it is rated for in most cases than 15 amps.
There is also a large "fudge" factor built into the switch design.
Old 09-13-15, 08:56 PM
Thanks! That makes sense.
Old 09-14-15, 12:21 PM
CasualJoe's Avatar
That is also why it used to be allowed and was quite common to run 14-2 switchlegs on a residential 20 amp circuit.
