Running electric to outdoor shed
Old 09-16-15, 09:39 AM
I have a shed about 30 feet from my house and main panel. Here is my plan to get electricity to it. Please advice if you am doing everything correctly.
-Install a 20 amp GFCI breaker in my main panel
-Run 3/4" grey PVC 18" deep from my house to the shed
-Use 12/2 THWN cable in the PVC
-In the shed I will have the wiring first come into a switch (standard toggle switch)
-After the switch I will install an outlet and a couple of lights.
The electricity in the shed will be used for lights and the occasional power tool (circular saw, hedge trimmer, etc.)
Any advice is appreciated. Thank you.
Old 09-16-15, 11:14 AM
ray2047's Avatar
Sounds good except for:
THWN is wire not cable but one white, one black, one green #12 THWN would be correct for conduit. (12-2 would refer to UF cable but best practice is to not use cable in conduit.)
