Nmd or nmwu to cord cap?
Old 09-24-15, 07:29 PM
Why is it that you cannot connect nmd to a cord cap but flexible cord is OK?
It's all connected to the same electrical source?
Whether it's nmd or flex - it could still catch fire.
Old 09-24-15, 07:32 PM
ray2047's Avatar
NM-b is not rated for use as a flexible cord so no cord cap. Why do you want to use NM-b?
Old 09-24-15, 07:51 PM
pcboss's Avatar
It all has to do with how the product is listed.
Old 09-25-15, 05:02 AM
I'm just interested in why rather than to actually use it.
It's all same guage copper wire so whether you connect it to a screw on a receptacle or a screw on a cord cap, what difference does it make?
Yes, the junction box contains fire risk but even a cord cap plugged into a receptacle could burn and that's outside the junction box.
Old 09-25-15, 06:11 AM
Tolyn Ironhand's Avatar
The jacket of NM-b/NMD is not very durable and would not handle up to the use like a cord will. Also NM-b/NMD normally has solid conductors while cords have stranded. Solid wires would eventually break if bent too many times.
Old 09-26-15, 03:20 PM
If it was fixed so the cable was never bent then presumably it would be OK?
I suppose code doesn't allow it because the assumption is that a cable external to the walls will be moved around at some point?
On that note, is there an external flexible cable rated for wet/damp - extension cable maybe?
Old 09-26-15, 04:03 PM
ray2047's Avatar
U.S. designations would be SOW or SJOW or SOOW. I don't know the Canadian equivalent.
