Old range hard wired how to wire new oven
#41
Received 0 Votes
The larger white and black cables come from somewhere under the cabinet I assume another stub up. The black one is what feeds the white one back out to the range. The large white one in turn was connected to the 240 and the old range.
The whole kitchen is on a slab, there is nothing ran into the wall, they all come from under the slab in pvc pipe. The breaker box outside has all the wires feeding into a large pipe I assume comes up into the house in that area somewhere.
#42
only other question i have is the old one worked, it was just old and the burners didnt work right anymore and the thermostat went out, so why cant these just work??
and here is what is in the installation manual:
WARNING: The neutral or ground wire of the power cord must be connected to the neutral
terminal located in the center of the terminal block. Ground strap must connect the neutral teminal
#43
I am assuming you mean it disappears into a wal
Assuming that is the correct conduit you are going have to dig a bit at the breaker panel to see where it goes. Does it go under the slab? Does it look continuous to the kitchen? I have a rough idea how to do this but can't start on guess. One other bit of info needed is that PVC conduit. If it is it is likely we can reuse it. If metal EMT less likely.
I have asked a lot of questions so I'll wait for the answers before continuing.
If the conduit does run under the slab or next to the slab buried and if the cables used are marked NM they were never code compliant and both the 120v cable and the 240v cable needs to be replaced. The good news is your breaker box is outside. That will make running new cable a bit easier.
