No ground on metal wall light
Old 10-03-15, 05:26 PM
Q
Received 1 Vote on 1 Post
I have an outside metal wall light that has no grounding screw anywhere.
Can I just drill a hole and put a metal screw in to ground it?
Can it be any screw uncoated, galvanised OK?
Any other recommended ways to ground it?
Old 10-03-15, 05:47 PM
Received 63 Votes on 58 Posts
Mounted on a Tee bar?
Metal box?
Does the feed wire have a ground?
Old 10-03-15, 07:06 PM
Q
Feed wire in the octagonal junction box has a ground, yes.
The light then has a metal box that fits over the junction box. This is welded onto the rest of the light, which is metal.
Old 10-03-15, 07:19 PM
Tolyn Ironhand's Avatar
Received 152 Votes on 136 Posts
If the metal junction box is grounded, then the metal light box is connected to the grounded junction box, it is then also grounded.
Old 10-04-15, 04:42 AM
Q
Paint in the way?
It's connected by a nut on a thread to the box.
Old 10-04-15, 07:34 PM
Q
Wouldn't paint on the metal box prevent a good ground connection?
Old 10-04-15, 08:04 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
But generally not in the threads.
