Confirm correct wiring
Old 10-05-15, 07:59 AM
johnam's Avatar
I would like to use 1 count down timer to control a combination bathroom heater & vent. The 3 way switch will choose heat or vent. Please let me know if my diagram is correct. Thanks for your time & expertise.
Old 10-05-15, 08:07 AM
Yes the diagram is correct as long as you connect the red wire to the common terminal on the 3-way switch. It is not always in that position, depends on the switch manufacturer, but it is usually colored black.
Old 10-05-15, 08:10 AM
Temporarily Suspended
If the wire that's marked hot is from the breaker box, shouldn't it go to the switch first?
Old 10-05-15, 09:01 AM
No, he's got it right. It needs to go to the timer first.
Old 10-05-15, 02:00 PM
johnam's Avatar
Finished project.....wired per diagram.....it works as expected. Thanks guys for assuring me that I was doing it correctly.
