Installing grounding rod
Old 10-06-15, 12:21 PM
doublezero's Avatar
Previous owner removed the grounding rod for some reason. The ground wire is hanging down over a pit. I'm going to go get a new grounding rod, drive it into the bottom of the pit, and attach the ground wire to it. Do I need to turn off the panel while working on it?
Old 10-06-15, 12:22 PM
ray2047's Avatar
No. .
Old 10-06-15, 02:24 PM
A pit for what?
Most often the ground rod is outside not inside.
Old 10-06-15, 02:26 PM
I get the impression the ground rod was outside and that it was dug up when a pit was dug. May be a drywell or something similar.
