Lights only work when something plugged into outlet
Old 10-07-15, 02:45 PM
B
Hi I recently plugged a vacuum into my outlet and it sparked, now my lights in that room will only work when something is plugged into that outlet...
Old 10-07-15, 02:47 PM
I
Received 45 Upvotes on 43 Posts
There is a loose or partially broken connection at that receptacle. The receptacle should be replaced and all of the connections remade in that junction box.
Abolos's Avatar
It might have been the technology trying to rewire itself (or at least reroute the power source)
Have you tried removing the outlet and seeing it that works?
Old 10-07-15, 02:48 PM
B
Thank you that was my thoughts.... Maybe when something is plugged in it is applying enough pressure to complete the connection. Thanks again
Old 10-07-15, 05:43 PM
Received 3,416 Upvotes on 3,063 Posts
Be very careful when you change that receptacle. I have a different take on the problem.
I feel it may be an open neutral in a multiwire branch circuit.
Be sure to check for voltage as your are pulling out the receptacle. Check from all wires to the box/ground.
