3 way used as standard switch?
Old 10-10-15, 01:58 PM
Greetings Guys,
More light switch and outlet work today. Replacing a light switch and found this, seems to be a 3 way switch used as a regular switch with a splice at common?
The light this switch is controlling only has one switch associated with it, however i found this today.
the bottom where the 2 blacks are, one screwed, one back stabbed, is labeled common.
However I dont think this a 3 way controlled light, i have no other switches for it.
Can you guys tell whats up here? There are 2 leads that come in the outlet box.
I'm thinking, just splice the two blacks down below add a short lead in and wire it like a regular switch?
Thanks again for any help.
Old 10-10-15, 02:02 PM
Into the box you have two cables.
Yes.... you can use a three switch as a single pole switch. You'd use the common and one of the travelers. You'd have to orient the switch so that up is on.
Connecting those two black wires to a short tail is a good idea.
Old 10-10-15, 02:05 PM
thanks PJMaxx, so no issues here then putting in a single pole switch as thats what this supposed to be anyway, right?
I am really learning a lot, thanks again!
Old 10-10-15, 02:08 PM
Nope.... feel free to replace with a single pole switch.
Old 10-10-15, 02:54 PM
Thanks, done and working fine.
Still struggling with to tape or not to tape the outside of the wing nut!
Old 10-10-15, 03:00 PM
If the wires are prepped correctly..... tape should not be needed or used.
