Converting a 4 jaw meter pan to 5 jaws
Old 10-11-15, 09:38 PM
I have a meter socket that accepts 240. However it does not work with meters that have a third metal to connect to Neutral. Could could I add a piece that will accept the neutral terminal of the meter - or do I need to change the entire meter socket?
(This might be rare - it could be that only in NYC they use meters that need to connect to neutral in order to operate)
Old 10-11-15, 09:57 PM
pcboss's Avatar
I would think you would need a new socket.
Welcome to the forums.
I changed the title to better reflect your problem.
The clamps that connect to the meter are called jaws. I'm trying to remember if I've ever seen a 5 jaw meter. All the residential ones I've seen have always been 4 jaw.
I would severely doubt that you could add a 5th jaw which leaves you changing the entire pan.
There are other electricians on board..... let's see what they think.
Old 10-12-15, 04:39 AM
Changing anything that is not recommended by the mfg. would void any UL listing,check with the mfg. and see what they may offer.
Geo
Old 10-12-15, 06:13 AM
I would think the only option is to contact the manufacturer of the meter socket and see if they offer a field conversion kit. Another possibility would be to see if they offer a 5 jaw socket in the same box configuration which you could buy and swap out the guts without having to change the whole socket.
Old 10-12-15, 12:02 PM
I would agree with checking with the manufacturer but keep in mind all the pertinent information is inside a locked meter pan.
