Wiring digital timer for exterior wall light
Old 10-12-15, 06:21 AM
Hi all-
First post here. I'd like to replace a wall switch for an external light (garage) with a digital timer (Utilitech). The current switch is wired with a black/hot and red wire (pictured on right). The white/neutral wires are all wired together but not connected to the switch. The timer should be wired as per the attached instructions. Not sure how I need to wire the red if at all? Do I need to run a neutral to the timer? Any help would be appreciated. Thanks!
Old 10-12-15, 07:41 AM
Black wire goes to L-I terminal. Red wire goes to L-O terminal. Run a white wire from the N terminal (either one) and connect it to the other white wires using the wire nut. Bare wire goes to the G terminal.
Old 10-12-15, 08:27 AM
Thanks! That worked perfectly!
Old 10-12-15, 09:28 AM
Good deal, glad to help. Enjoy!
