Powering smoke alarms
Old 10-15-15, 01:17 PM
Installing hard-wired smoke alarms as part of a remodel. Do they need to be on a seperate breaker, or can I hook into a light circuit for power?
Old 10-15-15, 01:18 PM
I
Received 45 Upvotes on 43 Posts
If your city follows NEC you can use a light circuit. Some jurisdictions have odd rules around smokes though, so verify any local codes.
Old 10-17-15, 07:49 PM
B
Mine were required to be on a dedicated AFCI breaker.
Old 10-18-15, 06:18 PM
CasualJoe's Avatar
Received 186 Upvotes on 167 Posts
Most smoke detector requirements are covered in the building and fire codes and not by the NEC. The most common requirement I have seen for new construction is that the detectors must be hardwired, interconnected and have battery backup. They usually are required in each bedroom, outside each bedroom area and at least one per floor, including the basement. Keep in mind that for many years all bedroom outlets have been required to be AFCI protected and the smoke detectors fall under that requirement.
I would put the smokes on a dedicated AFCI circuit.
