Underground Tee Splice
Old 10-16-15, 08:54 PM
I have a lamp post between my house and barn that is powered by a wire that is tee spliced into the run. I found it wrapped in tape and covered in tar when it failed years ago and tried a home brew repair that has not worked. From some research I think I understand that wire should not be an underground splice. The wire should run into a junction box above ground and then continue to the barn from the box. Is that correct? If so the fix would be an underground splice kit with a wire to the box and a wire out from the box with an underground splice kit to the wire continuing to the barn. Since the wire is in place I cannot lengthen it to reach the box.
Old 10-16-15, 09:06 PM
Received 3,880 Upvotes on 3,477 Posts
Look up "Scotch underground splices." I've used the epoxy potted ones many times. Stay away from the shrink wrap type.
Twenty years ago I was subbed out to an excavation company that was installing a new water line directly thru intersections and across companies front lawns. They cut and I spliced. All my splices are still good after all that time. I think I used at least thirty five to forty kits.
Old 10-17-15, 10:00 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Underground splices are allowed by the code.
Any underground slice should be an approved kit.
