Heat tapes
Old 10-26-15, 12:11 PM
Heat tapes
I'm considering installing heat tape on my roof to prevent ice dams (yes, I know, I should look at the insulation first, but I believe this is one case where I really do need the heat tape). It would be installed close to a shed that has a light bulb. The contractor I'm thinking of hiring suggested getting one of those light socket adapters and plugging the cable into it to avoid installing a new GFCI receptacle. Is that acceptable and safe? I don't want to burn my house down.
Old 10-26-15, 12:15 PM
avoid installing a new GFCI receptacle....... Is that acceptable and safe?
No.
You install a GFI protected device for safety. If you don't install it there is no safety consideration.
I don't think too much of a contractor that suggests a connection method like that.
Old 10-26-15, 01:09 PM
A light socket isn't even grounded, let alone GFCI protected. The idea is a non-starter.
