Junction plate partition wall
I am planning on erecting a partition wall to separate an area between my master bath and walk in closet. The point I've chosen has a junction plate cover right in the middle on the ceiling so I'm assuming I'll have to frame it on one side of it or the other. Is this against code to have an interior wall so close to the cover plate? Pretty much butting right up to the wall. Thanks!
What is a junction plate? Do you mean a junction box with a blank cover plate? Please post a picture with the cover plate removed. http://www.doityourself.com/forum/li...rt-images.html
It may be possible to move the junction box either into the attic, into the new wall, or to a different location on the ceiling. Can you open up the box and see what's in there?
It is a junction box in the attic with a plate covering it. I can see several conduit pipes feeding various outlets and switches in the bathroom and bedroom. I don't think it can be moved, but if it's ok to build the wall right next to it on either side, I guess that's my only option. As long as there's no minimum distance requirements.
