Bathroom GFCI outlet - 15A or 20A
Old 11-02-15, 09:40 PM
I am replacing a GFCI outlet in my bathroom near the sink. I can't tell if I should use a 15amp outlet or a 20amp outlet.
Old 11-02-15, 10:46 PM
ray2047's Avatar
You can use 15 amp as long as there is two places to plug in. A standard GFCI counts as two places. 15 amp GFCI receptacles are rated for 20 amp pass through so no problem powering down stream receptacles.
Old 11-03-15, 09:06 AM
Thanks Ray. Is there any advantage to using a 20amp outlet? This is purely for a bathroom in the home.
Old 11-03-15, 09:13 AM
No, you only need the 20A outlet if you have an appliance with a 20A (t-slot) cord. Perhaps if you have some sort of commercial grade equipment you want to use there.
Old 11-03-15, 09:44 AM
pcboss's Avatar
The internals are the same except for the slot.
