Electric Gate doesn't work
Old 11-04-15, 01:47 PM
I have a Mighty Mule swing gate opener. It has quit working. There is electricity to the transformer plugged into the outlet, but there is not any electricity getting to the arm itself.
I replaced the battery to no effect. However, after taking the new battery back out, I realized that it needed the negative post to be scraped to get to a shiny lead.
Other than that, does anyone have any ideas why the arm isn't getting electricity? Thank you!
Old 11-04-15, 02:30 PM
Welcome to the forums.
What's the model number of the opener ?
Old 11-04-15, 03:09 PM
I believe it is the 350. The control panel is on the underside of the gate opener, as opposed to being in a separate box.
Old 11-05-15, 02:13 AM
Grab you meter for some basic troubleshooting! Check 120 power at outlet, check voltage at transformer output, with wires disconnected check voltage at control (should see about 100% to 125% of voltage stated on transformer), check board and battery leads for blown fuse. Check transformer leads for continuity, check battery leads for continuity.
Old 11-05-15, 08:29 AM
The manual with diagnostics. Uploads/FM350-Mighty-Mule-automatic-gate-openers.pdf
There is a power switch on the unit and a battery fuse that could cause trouble.
Did you check the status lights on the unit ?
There is power, diagnostic, charge LED's on the board.
