Which 3 way switch isn't working
Two 3 ways controlling light. Both used to work fine. All of a sudden, Switch A will turn the light on or off only when Switch B is in the on position (up). When Switch B is down Switch A will not work at all. Switch A will turn the light on only if Switch B is in the on position (up) but not if B is in the down position. How can I determine which one is defective?
Temporarily Suspended
With 3 way switches, either up or down can be on. You need to inspect each switch & test them with a tester. Maybe switch B has a lose wire. Are there any dimmers involved? If so, replace it with a new 3 way switch.
Welcome to the forums.
It sounds like B is the problem switch. Usually I'll change them in pairs.
Be sure to mark the common wire at each switch. The common terminal on the new switch may or may not be in the same location as on the old switch so be sure which terminal is common on the new switch.
