Outlet screw grommets
I have no idea what these are called. The little metal/plastic squares that retain the screws on the rear of modern outlet plates. I'm always losing them, or finding them broken and then the screws go awol. I figure it's one of those things you can find cheap by the bag on eBay if only I knew what they were called.
I would call them keepers or retainers, although the trade probably has a name for them.
Do you replace enough receptacles to even worry about them? I have made a few by punching a nail hole in stiff paper and then cutting them into little squares. Then I asked myself "why am I wasting my time doing this?" and stopped.
I actually remove them before installing a device so that I can see if the device fits correctly in the box.
Originally Posted by joecaption
I agree 100%.
No way would I spend time and money on them.
I didn't ask whether you would use them, or whether you think I should. Merely if they had a name.
Fortunately noone is requiring you to!!
When you added "I figure it's one of those things you can find cheap by the bag on eBay if only I knew what they were called." we just assumed you were wanting to buy some.
That intent on finding the name, may want to try contacting the manufacture of switch and outlet plates to find out what it's called.
Just not a term 99.9999% of people in the trades would ever need to know.
Ask a shoe salesman what's the name is of the end of a shoe lace, a painter the name of the parts of a paint brush and expect to get blank stares.
When removing cover plates I put them and a the screws in a zip lock bag so I do not loose them.
I also have a box filled with old screws I've removed that where in good shape.
Anyways, we're clearly done here.
Thank you for the replies.
