method to surface mount subpanel
Old 11-12-15, 05:35 PM
I can't find the right thing to search for and can't find specific discussion... If I'm surface mounting a subpanel on sheetrock which has mounting holes much too narrow to hit the studs horizontally, what are acceptable ways to mount to the wall?
I could punch open the wall and put in some horizontal 2x4 to mount then fix the wall and mount the box on that.
I could mount it on plywood, which I've done with telco equipment many times, but I find differing info on that for a subpanel and fire rated plywood or somesuch.
I could hang it with drywall anchors. Seems too simple... but four of the big screw-in type would certainly hold it...
Whats the good word on this?
Old 11-12-15, 05:38 PM
pcboss's Avatar
Drywall anchors, toggle bolts, screws into a stud or a plywood panel behind would all work.
Old 11-12-15, 05:45 PM
Wow, too simple, that always makes me nervous.
Thanks
Old 11-12-15, 06:31 PM
You can catch a stud with two screws on one side and use the alternate method on the other side.
Old 11-12-15, 07:06 PM
CasualJoe's Avatar
You could bolt two pieces of 7/8" slotted strut horizontally into the studs and mount the panel on the strut with 1/4-20 spring nuts and 1/4-20 RHMS.
Old 11-13-15, 05:32 AM
Any of those methods are fine the key is to mount it securally.
