Main breaker off - power meter still runs (turning)
Hello,
I was testing my energy usage by taking measurements at my meter. At one point I noticed the following peculiarity.
After turning off the main at the breaker panel, I noticed the wheel on the meter was still turning ever so slowly.
Based on my calculations... using my houses Elstar meter with a common 7.2wh per rotation frequency. The wheel is divided into 10 sections, and each of those are divided into 10 tick marks. So I timed the movement of one full tick, which should be .000072 kwh; it took 19.58s (.005439 hrs), equating (.000072/.005439) to .013238 kw or about 13.2 watts.
I've heard that meters use some wattage in their workings, is this true?
Even if it is true, 13.2 watts seems high, is it?
Should the meter be dead stopped when the main breaker is off?
Am I calculating or testing something incorrectly?
Thank you!
Thank you!
It should be dead stopped when the main is off, unless you have something like a mains power indicator light or an automatic generator transfer switch which in some configurations can pull a small amount of power ahead of the main.
And be sure you do in fact have a single main breaker on your panel and it's not a split-bus panel. A split-bus panel requires you to turn off a couple breakers to actually remove all power to your house.
You can be certain by turning off all the breakers in the panel.
13 watts sounds like it could be an old oven clock or something similar.
you have a power leak
You could have an electrical leak . that amount would run two led light bulbs.
Have you UNPLUGGED your TVs etc.? the component that is waiting for a signal from the remote control uses more than you'd think.
In real simplistic terms I read it is kind of like a short but not enough to trip the circuit breaker.
Try turning off the circuit breakers one at a time. If you find a circuit that's leaking, turn it off until fixed.
google electric leak, a lot of people won't believe 'electricity leak'.
Please post after fixing I'm dying to know what it is.
My mom's bill was $87 many years ago, mine a half mile away and a much much larger house was $25. I turned off everything and checked the meter which was spinning like crazy. A neighbor came over. Ceiling radiant heat, thermostat behind a door she had never closed. Heating like crazy for a year. She had to open windows to cool the place, even in winter, even when raining. Old people!! never mentioned it to me, just happened to see the bill. Now I am 'old', and doing different things.
Littleaboutalot, to eliminate a problem with the main breaker also shut off all branch circuit breakers as suggested by Zorfdt.
