How to wire/make a light reset
Old 11-19-15, 12:08 PM
Hey there!
So i work at climbing gym where we sometimes have kids climbing and i want to make finish button, so when u reach the top u hit a button and the light start flashing for like 10 seconds and then turns off and is ready for the next kid to hit IT..
So im wonderng how i can make this possible? I know basics and soldering..
I thought i should buy 12v light and somehow make IT work..
Anybody that could help Me??
Thank you!
Old 11-19-15, 03:01 PM
Tolyn Ironhand's Avatar
A 12 volt DC strobe light, like you could have on a car/truck, would be easiest and safest way to go. You could power it with a battery (which you would have to change) or run it off a DC power supply that you plug in someplace.
You could wire it like a start/stop station. Start button on the top and stop at the bottom. It would just have to be reset each time.
Old 11-19-15, 05:24 PM
ray2047's Avatar
Sounds like a job for a 555 IC but that is where my knowledge ends. There are lots of circuits for 555 ICs on the net.
Old 11-20-15, 07:03 AM
I think the left diagram at the link shown would be perfect for your project. Personally I think a rotating beacon would impress the kids the most.
Circuits Page 9
555 timer Mono stable (one shot) circuit
The two circuits below illustrate using the 555 timer to close a relay for a predetermined amount of time by pressing a momentary N/O push button. The circuit on the left can be used for long time periods where the push button can be pressed and released before the end of the timing period. For shorter periods, a capacitor can be used to isolate the switch so that only the initial switch closure is seen by the timer input and the switch can remain closed for an unlimited period without effecting the output.
In the idle state, the output at pin 3 will be at ground and the relay deactivated. The trigger input (pin 2) is held high by the 100K resistor and both capacitors are discharged. When the button is closed, the 0.1uF cap will charge through the button and the 100K resistor which causes the voltage at pin 2 to move low for a few milliseconds. The falling voltage at pin 2 triggers the 555 and starts the timing cycle. The output at pin 3 immediately moves up to near the supply voltage (about 10.4 volts for a 12 volt supply) and remains at that level until the 22 uF timing capacitor charges to about 2/3 of the supply voltage (about 1 second as shown). Most 12 volt relays will operate at 10.4 volts, if not, the supply voltage could be raised to 13.5 or so to compensate. The 555 output will supply up to 200mA of current, so the relay could be replaced with a small lamp, doorbell, or other load that requires less than 200mA. When the button is released, the 0.1uF capacitor discharges through the 100K and 2K resistors. The diode across the 100K resistor prevents the voltage at pin 2 from rising above the supply voltage when the cap discharges. The 2K resistor in series with the 22uF cap limits the discharge current from pin 7 of the timer. This resistor may not be necessary, but it's a good idea to limit current when discharging capacitors across switch contacts or transistors.
There are many 12V timer kits available on eBay...such as THIS ONE
