Hum in wall and electrical panel
I'm getting a hum in the wall that seems like it could only be the baseboard as it is most obvious when they come on in the morning. It's a pulsating hum with a short gap in between and it changes, after 30 mins it slows down as heaters are not on as much as the rooms are at temperature.
However, there is also a hum when I put my ear to the electrical panel. It reduces when I turn certain breakers off. Are the breakers likely to need to be changed?
The doorbell transformer was already off. The hum is annoying though as it reverberates through the empty spaces in the walls.
The ones that buzz the most seem to be 20A dual pole for heaters. I'm not sure if the wall buzz congress from the panel, the heaters, or both.
