How to convert this outdoor junction box into an outlet?
Old 12-01-15, 01:33 PM
Question How to convert this outdoor junction box into an outlet?
Please mention specific parts.
I have a fair bit of DIY experience doing indoor electrical, but not outdoor.
Old 12-01-15, 01:38 PM
This junction box seems to lead to my lawn outlets (to be used for water fountains etc.)
Old 12-01-15, 02:36 PM
That's called a pull ell. It's not designed to have a receptacle mounted to it. You may be able to pull the wires out of the pipe, cut the pull ell off and replace it with a pull tee. Then you could put a short piece of PVC up to a weatherproof electrical box.
Old 12-01-15, 02:59 PM
How would you stabilize the new electrical box so it doesn't move around?
Old 12-01-15, 03:47 PM
Instead of using a short piece of PVC to the box.... use a piece of seal tite. It's a flexible conduit you run wires thru. Then you can fasten the box to the seam between the rocks or set a wooden post to mount to.
