Move 240v range outlet
Received 0 Votes
Hello,
I have an electric range outlet that is located where I cannot push my oven back against the wall.
I have opened up the wall to see if there was enough slack in the feed wire to move the outlet lower 8", but no luck. The wall is only 3.5" deep on the inside so recessing the outlet is not possible either.
Is there safe way to move this outlet without running a new feed wire back to the electrical panel? (80+ feet).
Is it possible to re-purpose the existing outlet box as a junction box and splice a new length of feed wire to move the outlet into a new box lower on the wall? if so, how would this splice be done safely?
Any assistance is appreciated.
Thanks!
Thanks!
Received 0 Votes
There are 4 wires (3x8 AWG, 1x10 AWG) in the outlet box connected to a double pole 40 AMP breaker at the panel.
Currently, the box itself is inside the wall and the outlet is "flush" with the surface of the wall. I cannot push the box back any further into the wall because it is too shallow and I cannot get the outlet recessed. This makes my range stand out about 2" from the wall due to the thickness of the plug.
If I could move the box down the wall about 8" inches, there is a void in the back of the range that would allow my to push the range back to the wall.
I was hoping to remove the outlet from the existing box, splice in a new length of wire to another box lower in the wall where I will put the outlet. I would leave an accessible cover on the new junction box.
I'm not sure what I can use to safely splice 8 and 10 AWG wire together, or if it's even safe to do so. Any advice here would be helpful.
Thanks again.
Thanks again.
[ATTACH=CONFIG]59521[/ATTACH]
Bummer is the splices are about $11 each, while wire nuts are about 50 cents each.
Received 0 Votes
Thanks for the advice!
It's copper wire coming from the ceiling, but there is zero slack or extra wire. I went into the attic and traced it back to the panel and i cannot get the 8-10" I need to move the outlet.
I'll probably opt for the wirenut approach, maybe with some electrical tape for extra protection.
Received 0 Votes
I pulled apart this outlet and it turns out that this is a 60 amp circuit and the wires are larger than I previously thought.
There are 3 x 6 AWG wires and a 10 AWG ground wire, so I don't think I can use the Big Blue wire nuts to splice a connection.
Can you send me the source for the insulated splices pictured above? I think that's what I'm going to have to use to move this outlet.
Thanks!
Thanks!
