Help with wiring!
Help with wiring!
Hi, since 3 weeks, I've been renovating my kitchen. An electrician has already made the "rough". Now, everything is installed, the only thing left is... putting 3 outlets for countertops and 1 dimmer for under cabinet lightning.).I thought it would be simple but damn, I just can't figure it out. I little bit of help would be appreciated. Two outlets are really simple (black,white, red and ground).
You'll find a picture of the wires. It's suppose to be the dimmer and an outlet.
Thanks for your answer
Welcome to the forums.
Not quite following you there.
I'm a little confused at the wiring I see in this box. This wiring IS NOT device ready. There are too many current carrying hot conductors. There should be two ground tails.
I see a neutral. That would be for the receptacle. It looks like there may be two feeds there but one is on a two wire cable and the other is on a three wire cable. You're going to need to find out which circuits feed that box and let us know. I labeled the wires awaiting your response.
Is this wiring new? The wiring for the receptacle should be thicker than the lighting in most cases.
I see four NM cables, but only one of them has a ground wire.
Surely this cannot all be new wiring. The sheathes on all 4 cables are white signifying 14-2 NM-B cable. IF this is new wiring the countertop receptacles are required to be on 20 amp circuits.
Hi Thanks for your answers. i finally got it. For your information all cable is brand new. This was the picture of the job done by the electrician right After he finished.
Regards,
Regards,
The biggest problem that was pointed out is that this #14 wiring is undersized for a kitchen counter receptacle.
I don't recognize the style of box but it looks like each ground wire goes to a captive screw.
