Wire 110/220V Motor back to 110, No Diagram
Old 12-12-15, 06:32 PM
I bought an old band saw with a dual voltage motor, which is wired for 220V. I need to wire it back to 110 but it has no diagram. Hopefully, it's simple enough that a knowledgeable member here can point me in the right direction.
The terminals are number 1 - 4 from left to right.
I removed the cord, which was connected to terminals 1 and 4.
Three brown wires come from the motor and connect to terminal 2.
Then there are two white wires coming out of the panel, at the bottom left. One of them connects to terminal 4 and the other (not visible in the photo) goes down and back into the motor.
As I said, it's currently wired to run on 220V supply. I need to switch it to 110V.
Thanks!
Old 12-12-15, 07:41 PM
pugsl's Avatar
Name and model # might help somebody.
