Kitchen Wiring Help
Old 12-20-15, 08:47 AM
Kitchen Wiring Help
Hi Everyone,
I could use some help with the wiring of a GFCI outlet and switch in my kitchen. I moved into my house a couple months ago and everything was working fine but recently when I have been turning on the switch that activates my kitchen cabinet lights it has been causing the outlet to trip and lights to turn off.
I have attached a diagram of how the outlet and and switch are currently wired. There are two other outlets in this same circuit. One is to the left of the outlet and the other is to the write of the switch. My concern is that these may not have been wired properly. Please let me know if any additional info is needed.
Name:  Wiring Diagram.png
Thanks
Old 12-20-15, 09:01 AM
Received 1,042 Votes on 966 Posts
Your diagram shows the lights connected to the line side of the GFI receptacle which is correct.
I'm assuming the incoming power also attaches to the same line terminals ?
In your diagram you show a red wire.... is one of the wires on the switch red ?
You're showing two lights as always live and one light switched.
Old 12-20-15, 09:20 AM
Sorry my diagram should have been more clear. Those actually aren't the lights. Those are where the wires are entering the box.Name:  16c8b704-c08d-4169-80b1-2807d1c27893.jpg
Old 12-20-15, 09:29 AM
Ahh... ok.
Which receptacle to trip...... not the one in the diagram ?
You show the lights powered off the black wire which is connected to the line side of the receptacle.
Old 12-20-15, 09:32 AM
Ya the receptacle in the diagram which kills the one to the right of the switch (not pictured) as well.
Old 12-20-15, 09:38 AM
There are two sets of terminals on the back of a GFI.... line and load. You're showing using line only. That means that the GFI is not protecting anything downstream. Is it possible the wiring is different on the back of the receptacle then you are showing ?
It can be hard to read the line and load markings.
Old 12-20-15, 07:35 PM
A rapid-start fluorescent fixture cannot be powered through a GFCI. Starting the lamp trips the GFCI through capacitive coupling from ground to the lamp tube which is needed to start the lamp.
Old 12-20-15, 08:47 PM
In this case.... the OP has illustrated connecting the lights to the line side of the GFI receptacle which means that the lights are not powered thru the GFI.
Old 12-21-15, 05:10 AM
Handyone's Avatar
Look at the wire nut with the 3 black wires.
1 of these wires is source hot
1 provides power downstream
1 is a pigtail (which should go to the line side hot on GFI)
How did the light switch get power? Maybe it was a short piece of wire from the GFI load terminal to the switch and this would be wrong.
Undo the wire nut, add another black pigtail.
One hot pigtail goes to GFI line terminal, the other to the switch.
Old 12-21-15, 06:09 AM
Thanks everyone for the help! It turns out it was a connection of the upstream outlet. I removed the outlet and connected the two black wires together and everything downstream lit up. I will just add a pigtail to add the outlet back.
Thanks again,
Mike
