lost power to one room
Received 0 Votes
I lost power to one room in house. I have checked breakers. I even took cover off to make sure there was power coming from all breakers. I tested some of the outlets with a meter. I have nothing from black to white or from black to ground. I replaced some of the outlets because they where back stabbed.
Welcome to the forums.
The problem is either at the last working receptacle or the first dead one.
You'll need to shut the circuit off, identify all the now dead devices, turn the power back on and determine the closest point between the working receptacles and the non working receptacles.
Could there be a hidden GFI receptacle in the mix here ?
Or do you think replacing the receptacles caused the problem?
