How to wire a Leviton Combination Switch & Pilot Light
Old 12-23-15, 07:14 AM
D
Hi,
I have a switch in my stairway that is used to turn on the light in my basement. As i always forget to turn it off, i would like to turn the regular switch into a switch with a pilot light that stays on while the basement light is on.
I have just one wire coming into the box (no wire going out) with a Hot Black wire, a white wire and a copper wire.
Can I wire a combination switch with a pilot light? The wiring diagram is a bit confusing showing a Hot wire, a load wire and Neutral wire.
Thanks for your help.
Dan
Old 12-23-15, 07:31 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
No, you have one cable. A wire is a single conductor. You have a cable., two or more wires in a metallic or non metallic sheath. You have a basic switch loop, no neutral.
You have hot and load but no neutral so the switch won't work. You may be able to find a similar switch that does not use a neutral but they will only work with incandescent bulbs.
To use the switch you have you could replace the 2-conductor cable from the light with a 3-conductor cable or if easier run power to the switch from a near by source and abandon the original power source at the light.
