Front porch lights - help!
Received 0 Votes
Hello,
I am posting this because I do not know how to search for this kind of problem.
My 2 front porch lights tend to go out frequently, as in after a couple of weeks. They go out separately. When I replace the bulb(s), they work fine. When I take the old bulb and test it on another light source, that bulb works fine too. I am completely stumped, as I don't know how to single out the problem.
Any suggestions?
Thank you,
Billy
Any suggestions?
Thank you,
Billy
Welcome to the forums.
That doesn't make a lot of sense. You change the bulb and the fixture works. You try the old bulb and it's good.
The only thing that makes sense is that the sockets are burned, corroded or shot.
How do the bulbs look.... burned, corroded ?
Received 0 Votes
Thank you for your response. The bulbs look fine to me (as this is a previous issue) but I can take a closer look when I get home. Agreed, I am stumped on this one, because all devices seem to have their moment when they are working fine.
Sometimes the filament can break, but when moving the bulb in a different orientation the filament will make contact again and light.
Light bulbs near doors can be broken from the slamming of the door. Try using rough service bulbs.
