Help needed regarding the extension box
Old 12-28-15, 08:50 AM
pcboss's Avatar
Received 103 Votes on 89 Posts
Based on the NEC which does not apply you you there are several issues. The wires are the wrong colors and also cannot be used without conduit.
Old 12-28-15, 09:12 AM
@pcboss: thanks for ur quick reply. Regarding wire, I had 24 Metre of this blue color 1.5mm wire, which I had cut it into 3 bits (8metre each for line, ground & neutral).
By the way I'm gonna use this extension box temporarily only. My intention is to use this extension box in the upstairs to power up my laptop & mainly I ll be using this for just around 2 or 3 weeks. So can I use it without the conduit?
