Wall oven, furnace and water heater wiring
Hello.
We are renovating our kitchen with plans in the future to do other rooms. Currently we have a propane oven and furnace. We want to eventually switch the oven and furnace to electric and move the water heater to a better location (it won't move much, just 5 feet or so).
Since we are ripping out everything, including walls and insulation, we are able to run new wire now. To be clear, I don't mean hooking the wire up to anything, just getting it in place to eventually be hooked up since it is easier now before we put up the new dry wall.
I just didn't know what wire we should run. I assume each of these will need its own breaker and when we are ready to hook the new appliances up we will hire an electrician to hook the wires up to the breaker.
Thanks so much in advance!
Welcome to the forums.
An electric oven..... is a wall mounted oven only OR stove/range ..... oven and cooktop ?
An electric furnace or a heat pump system.... with A/C or without A/C ?
I think you need to research what you may want to switch to in the future before deciding on what cable to run.
Agreed, the heat pump might need up to 90 amps depending on the backup heat.
The WH will need a 240 vo,t 30 amp circuit with 10-2 wiring.
A freestanding electric range and electric water heater are easy to plan for, but the heating isn't quite that simple. Most heat pumps are installed along with a conventional electric furnace which provides the air handler function as well as the emergency heat function. Regardless, the furnace needs to be sized to the full heating load. You need to have the heat load calculated and the furnace and heat pump or A-C unit sized before you can plan the wiring for them. Electric furnaces are typically sized by KW ratings such as 10, 15, 20 and 25 KW. You need to know what size as well as how many circuits the furnace will need; could be one, two or three.
My guess is that you'll need to upgrade to a 200 amp electric service. In addition, you'll need to talk to your electric utility about the new loads so they can evaluate the transformer and service drop requirements.
Just curious, what city are you in or near?
Hi, you may also want to contact the electrician you plan to hire to be sure he is OK with you running the cables,rough wiring should be inspected before any drywall is installed.
So sorry for not including more info. We are in a trailer and would likely only go up to a 50 gallon tank for the water heater. For the electric furnace not sure what we will get, but it would need to be tall and skinny to fit the spot. I understand the main issue with mobile homes is the small vent system, but prior to all this we plan to change it all out for standard.
We are not looking at a A/C heat unit, just a simple furnace. For the oven it is not a range or double oven. Just a single wall oven, however I am wanting one with convection if that makes a difference.
What I really want to know is what gauge/ type wire these items would need to get the wire in the walls before we drywall.
Thanks again!
Thanks again!
Standard residential electric water heater is 30A no matter what size it is. So, pull 10-2 wire and install 30A double pole breaker for it.
If current water heater is electric, simply extend wire to new location. (in junction box of course.)
By wall oven, do you mean built in oven that goes inside cabinets?
Some of those require only 30A and most require 40A and most of them are hardwired.
Pull 10-3 (3 wires + ground) for 30A or 8-3 for 40A. Double pole 30A or 40A breaker.
If you don't know what you will get, just pull 8-3 and choose breaker size later. That is no problem putting larger size wire than required other than being harder to work with.
If you mean oven range (one with stove on top), most of them uses 40A and some 50A.
Pull 8-3 for 40A or 6-3 for 50A. Double pole 40A or 50A breaker.
Then install NEMA 14-50 Outlet (can be surface mount or wall mount. Wall mount will require double gang junction box). This is 50A 4 prong outlet.
As for the furnace, it really depends on what you are installing, but I doubt that it will be more than 50A for trailer home. You will probably need 6-2 wire. If think you need more than pull 4-2 wire to be safer (Up to 70A on 4-2 NM-B).
All the wires I mentioned are NM-B, which is standard romex wires.
Use following chart.
Ampacity Charts
Ampacity Charts
Again
Talk to your heating guy, you cannot plan for the wiring without knowing what size furnace and how many circuits are required.
