Can anyone identity this fuse
Old 01-03-16, 02:46 PM
X
I need to replace a fuse but i cant find it online. I was hoping someone understood the numbers on it and could tell me which fuse i needed.
It is on a 120VAC line. It is ceramic.
Lf 20 A /500VP
And
505 c7 RU us. (the RU is large font and the R is backwards).
Thanks.
Old 01-03-16, 02:49 PM
Tolyn Ironhand's Avatar
Received 93 Votes on 83 Posts
A picture would help, but it sounds like just a 20 amp fuse.
Old 01-03-16, 02:58 PM
Received 595 Votes on 560 Posts
It looks like a LittleFuse 20A ceramic fuse.
Old 01-03-16, 03:02 PM
C
Received 1 Vote on 1 Post
If you gave us the dimensions and a photo, we could probably give you a replacement part no that would work.
Old 01-03-16, 03:08 PM
pcboss's Avatar
Received 42 Votes on 37 Posts
The UR is for Underwriters Recognized, a testing lab.
Old 01-03-16, 07:05 PM
X
I didnt include a photo because it is an inline fuse without an inline fuse holder. They soldered the wires to it, then it looks like they glued a sheet of rubber to it, then a heat shrink tube. By the time i hacked, wacked, slashed and tore through half of it so i could test it, it wasnt very pretty. I shattered it fighting to get the last bits off so i could read the numbers.
I dont see the button to attach a pic, but if i find it, i will attach what i have.
As for dimensions, i cant measure it now, but it looked like a standard 12V automotive size.
Old 01-03-16, 07:09 PM
X
Found the button, it is not on my mobile version.
Old 01-03-16, 08:31 PM
That's a Littlefuse 505 series fuse.
littelfuse/media/electronics/datasheets/littelfuse_fuse_505_datasheet.pdf.pdf
Mouser is a god place to purchase it from. No minimum order and fast service.
0505020.MXP Littelfuse | Mouser
Old 01-03-16, 08:49 PM
X
Great, thank you.
I thought it was going to some weird, oddball thing.
Also, do they make inline fuse holders for these? Or do i have to solder it the way they did?
Old 01-04-16, 05:18 AM
Geochurchi's Avatar
Received 26 Votes on 25 Posts
Hi, that appears to be a standard size fuse 1.25" long be 1/4" Dia , any inline fuse holder should work,as long as the voltage rating is greater than or equal to the circuit voltage.
