Splitting light circuit
Old 01-03-16, 08:16 PM
Hello, I have a branch circuit on the second floor of my detached garage that has one switch that controls six ceiling lights (60 watt bulbs). The power feed is a 15 amp circuit with 14/2 wire that comes in from a panel on the first floor, goes into the switch and then out to the lights. I would like to rewire the circuit to add a second switch so each switch controls three lights. Is it to code to split the hot wire in the switch box and feed it into two switched circuits? Thank you.
Old 01-03-16, 08:26 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes. Install a double gang box or use a duplex switch in the existing single gang box. If you use two simplex switches in a double gang box you will need to pigtail the hot to the two switches.
Old 01-03-16, 08:45 PM
pcboss's Avatar
Received 35 Votes on 30 Posts
As long as the box has room for the additional cable your plan is fine.
