Why the weird glow?
Old 01-06-16, 10:15 AM
Why the weird glow?
I wired my garage for 30 florescent fixtures on five 15 amp circuits. Each home run of the 5 circuits goes to one switch. Two circuits are on three-ways with the black and white wires travelers to the second switch and the red to the COM terminal of the second switch and to the black from the lights.
I am going to insulate the attic before I install the lights so I have been checking the wiring with a voltage detector taped to a pole. It glows brighter the closer I get to the HOT wire. But why to a get a glow when I get near the black wires even with the switches "off"? And brighter (normal) when the switch is "on"? The other wires on the single-pole switches have no glow when the switch is "off".
I have checked with my Gardner Bender Circuit Alert and it flashes and beeps only when the switches are "on".
Old 01-06-16, 10:47 AM
Received 479 Votes on 449 Posts
A non contact tester is/was only designed to inform you that a hazardous voltage is in the area. It picks up voltages inductively that travel between live and dead wires. You cannot use it to make any meaningful tests. You should pre-test your circuits with a light bulb in a socket with two wires or a voltage tester.
Old 01-06-16, 04:05 PM
Is there another way? It is not feasible to get up a ladder to boxes. Why does the non-contact tester act that way?
Old 01-06-16, 04:41 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
A non contact tester does not detect voltage despite what it may say on its packaging. It detects electromagnetic fields. Any electromagnetic field can set it off. A lot of things can create electromagnetic field.
Old 01-06-16, 07:03 PM
Any other testing methods? Any reason to think something is wired wrong?
Old 01-06-16, 07:09 PM
ray2047's Avatar
If it works, there is no smoke, and the breaker doesn't trip it is okay. Those are the best tests.
